DX Spots
May 17th, 2026. DX Spots is available in version 1.6, will be released on or before May 22nd 2026.
Display spots submitted to PSK Reporter which are relayed by a MQTT Broker running on a high performance Akamia node.
Spot Format
Each spot consists of these fields:
- Sequence
- Frequency
- Band
- Mode
- Signal level
- Time stamp
- Sending station call, square, country
- Receiving station call, square, country
Note: The country is the ADIF country.
Spots are displayed as they arrive, currently no on-demand database.
Bandwidth
To reduce bandwidth from the broker, filtering is required for 80m up to and including 10m. Filtering requires at least one field below to be set in a definition:
- Receiver callsign, square or country.
- Sender callsign, square or country.
Without filtering the bandwith from the broker could be excessive. For LF and VHF+ no filtering is required due to the lower number of spots sent on these bands. In a later version the bandwidth restriction may be reduced.
Definition Editor
The editor is designed to be intuitive.
- Mode is free-format. The dropdown list contains commonly used mode, to add a mode not in the list just enter in the Mode field.
- Locator squares are four-character Maidenhead format.
- Countries are ADIF / DXCC.
MQTT Broker
An MQTT broker is a central component in the MQTT protocol, facilitating communication between devices in a publish/subscribe model. It acts as an intermediary, receiving messages from publishers and distributing them to subscribers based on topic filters. This architecture is widely used in IoT systems for its lightweight, scalable, and efficient communication.
Key Features of MQTT Brokers
- Message Routing: Brokers route messages from publishers to subscribers based on topics, ensuring efficient delivery without direct client connections.
- Scalability: MQTT brokers handle thousands to millions of simultaneous connections, making them ideal for IoT and M2M (Machine-to-Machine) communication.
- Security: They support authentication, encryption (e.g., SSL/TLS), and other security measures to protect data.
- Session Management: Brokers maintain client session states, ensuring message delivery even when clients reconnect.
- Integration: MQTT brokers integrate with cloud platforms (e.g., AWS IoT, Google Cloud IoT) and databases for seamless IoT solutions.
