SDR Console, Beta July 26th 2026
Simon Brown • July 27, 2026
July 26th, 2026
Reuter RSR200B
  • Added initial support.
Fobos
  • Finalised support for Fobos SDR, only the Agile firmware is supported. Some early Fobos SDR units had HF2 and HF1 swapped on the case printing.
FFT
  • When using NVIDIA CUDA for the FFT the returned buffers now use memory from the heap rather than pinned memory (*).
  • Reduced the CPU load in the FFT Helper DLL. The data from the FFT (CUDA, IPP, OpenCL) is processed to match the display DIPs. When running Broadcast-FM with x4 resolution there were 550 FFT bins per display pixel (DIP). These 550 bins were averaged which takes quite some processing, especially when running a matrix display with many receivers enabled. I now down-sample the bins to a maximum of (about) 32 which doesn't affect the display or any DSP but does reduce the CPU.
Frequency Database
  • Loading of the frequency database into memory-mapped backing now much faster.
Pluto
  • TX Doppler support for Pluto / LibreSDR. Have tested this by adding debug info, seems OK 🙂 .
RDS
  • Added variable font size in the RDS editor window.
  • Forced uppercase of PS text in the RDS Editor removed.
  • Change to RDS Logfile updates while the editor is open & visible. Updates are now allowed, previously not so.
Recordings
  • Fixed font size error in the playback, navigation window (was incorrect logic).
  • When starting the video recorder a sanity check makes sure the selected folder exists and is accessible.
Satellite
  • Satellite definition file format has changed, no need to update your settings but support for the new OMM (.xml) format is included.
  • I'm hosting satellite data on my (new) Akamai server, these is currently a cache of the Celestrak data. I'll add a web page soon which explains what's been happening.
Transmit
  • Audio mute is now a per-profile setting.
Other
  • Fixed an error opening the matrix display while the SDR was already started.
  • Crash when selecting "Configure" from the Select Radio window fixed.
  • Does not create an error when the graphics driver restarts.
February 10th, 2026
Pluto
  • Correct the FIR filter definitions, this has improved reception.
November 1st, 2025
Analyser
  • Analyser tag window change, as suggested by Jim.
  • Analyser tags now saved and restored correctly.
  • Analyser font size now supports small, medium and large.
  • Analyser loads saved projects faster.
  • Saving project now much faster and uses less memory.
  • More display lines available if you have enough RAM:
  • Less than 16GB then 50,000 lines.
  • 16GB to 32GB then 100,000 lines.
  • 32GB or more then 250,000 lines.
  • Fixed minor font issue with definition window.
  • Fixed issue scrolling when more than 32768 lines in display.
Data File Playback
  • Selecting a playback folder now creates the list of files much faster.
Emulation
Added a diagnostic check for the use of emulators. This code only works on W10 and above, so I dynamically load IsWow64Process2 from kernel32 which avoids issues on older versions of Windows.
In the logfile you see something like this:
05:23:48.185: Vendor ....: GenuineIntel
05:23:48.185: Brand .....: Intel(R) Core(TM) Ultra 7 265K
05:23:48.185: -
05:23:48.185: x86 Emulation:
05:23:48.185: Process .......: 0x0000, "Not emulated"
05:23:48.185: Architecture ..: 0x8664, "AMD64"
05:23:48.185: -
Favourites
  • Updated the default 60m bandwidth.
  • Changed Broadcast :: VHF CCIR title to Band II.
  • Groups now have user-selectable files.
  • Default definitions renames to main.
  • Changed the ribbon bar, Selection entry to Options (see image below). The dropdown options have been replaced with a single window, allowing more room for text.
Locked Receivers
  • If the program is stopped or a favourite created when a receiver is locked, this caused problems with the receiver being locked but no indication. With this kit receiver lock state is not applied in a favourite definition.
Logfile
  • Automatically save the logfile when closing, really added so I can check program responding correctly to Shutdown and Restart.
  • Old logfiles are purged after the program has been running for one minute.
Logging
  • Added logbook FA option as below, FA is the command to read/write RX1.
Narrow FM
  • Added 150Hz CTCSS squelch tone.
  • De-emphasis is now optional, selected from: Ribbon bar, Receive, Mode..., Narrow FM.
Persistent Display
  • Got a crash inside the persistent display logic, my sanity checks weren't good enough so have improved this.
Remote Server
  • After connecting to a remote server, the input fields can now be edited to change connection parameters.
Ribbon Bar
  • View panel tidied up.
Signal Meter (SMeter)
  • Added more presets for the Signal meter, Ribbon bar, View, Spectrum, Signal Meter.
Spectran ECO
  • Changed SPECTRAN path order to pick up DLLs from the SDK folder rather than the main folder.
Status Bar
  • GPU, Audio entries on status bar now optional, selected from Program Options, Performance, CPU Memory.
System Shutdown / Restart
  • If SDR Console is running when the system shuts down or restarts then SDR Console closes gracefully. What happens - five seconds after SDR Console receives the SHUTDOWN message a timer calls the OnClose() processing, so you have five seconds to about the shutdown / restart.
Text Size
  • Fonts now scale correctly when a non-default Accessibility > Text Size is selected (see image).
Previous Kits...
I'm now back to 90% SDR Console support, so here's the first beta for at least eight months. Scroll to the bottom for a link to the beta kit.
  • The source is fully archived, so crash dumps can be analysed.
September 4th, 2025
  • Added Simple-Radio-Control-Protocol (SRCP) as per JB's Dx Info and tested only with StationList. SRCP specifies a method to control a radio and get its status back to StationList (or a similiar application). To avoid any headache on user and software writer a very simple method was chosen. Communication is done by sending UDP string messages.
  • If there are other logging programs which support SRCP please let me know.
  • I have not added support for RDS, only frequency changes.
  • After the first message is sent from StationList the protocol is activated.
  • This should be documented somewhere in the Settings somewhere, but where?
  • What's missing?
August 30th, 2025
  • If the RDS Database cannot be opened / created an error is now displayed.
  • RDS Logfile window now shows Entry when displaying all fields, see image below.
  • RDS Logfile window now supports data sorting by clicking on the column headers.
Radio Data System(RDS) is a communications protocol standard for embedding small amounts of digital information in conventional FM radio broadcasts. RDS standardizes several types of information transmitted, including time, station identification and program information.
August 28th, 2025
  • SSB / AM squelch was missing the start and cutting off too soon. Also, the Raised cosine rise/fall was missing. Now, the SSB/AM squelch is more pleasant to listen to. Note: SSB / AM squelch uses voice activity detection, it is not rf-based.
  • RDS Logfile display no longer auto-updates if any of:
  • Edit window is visible,
  • Mouse has been active in the previous five seconds,
  • First entry is not visible.
August 23rd, 2025
  • Supports Winradio IQ files > 4 GB. These files, like ELAD's do not honour the WAV format correctly, but hey-ho.
  • When searching for Airspy HF+ / Discovery / ... SDRs the firmware is now shown in the Options field in the list of SDRs. Also shown in the logfile when connecting to the Airspy.
  • Option added to support logging programs when using a transmit up/ down converter definition, as we do with the Pluto on QO-100, see image below.
  • Previously FA, FB, ... returned the receive frequency (10 GHz) but on QO-100 we're actually transmitting at 2.4 GHz on the up-link.
  • When enabled, the actual transmit frequency (2.4 GHz) is returned.
Mode Mapping page is now Frequency, Mode.
June 28th, 2025
  1. Scheduled recordings now have an option to shut down the computer when the recording is finished.
  2. Streaming now compresses the data when the bandwidth is 5MHz or greater.
June 26th, 2025
  1. Preset recording definitions now include the action to take when the recording finishes, see image below.
  2. The Stop button in Ribbon bar, Home, Radio now stops the recording playback.
June 25th, 2025
  • Left and Right channels in Broadcast-FM swapped over, was reported that they were previously wrong. Please check!
June 22nd, 2025
  •  Custom layouts now restore the collapsed / expanded state of the Receive and Transmit panes.
June 20th, 2025
  • When the Microphone dropdown is opened in the Transmit panel the list of capture devices is re-enumerated and updated, so anything you plug in / out is reflected in the dropdown list without having to restart. Unplugging the microphone you are using is not supported, but you don't do that, right?
  • The TX relay can now be connected after starting, it will be opened when the next transmission is made.
June 19th, 2025
  • Reworked some MIDI support to reduce / eliminate crashes.
June 18th, 2025
Kits
The beta kits are here: https://www.sdr-radio.com/download#Beta
RadioClear AI – A New Approach to Speech Noise Reduction Improving Weak Signal Reception One of the biggest challenges when listening to weak radio signals is separating speech from background noise. As signals become weaker, the noise can overwhelm the speech, making conversations difficult or sometimes impossible to understand. Conventional noise reduction has been available in software-defined radios for many years. Most systems analyse the received audio, estimate which frequencies contain noise, and reduce their amplitude. This can work very well, but there is always a compromise. Too little suppression leaves distracting background noise, while too much can make speech sound metallic, watery or unnatural. Important speech information may disappear along with the noise. For some time, I have wanted to develop a better approach for SDR Console, particularly for weak SSB reception. The objective was not simply to produce quieter audio, but to improve intelligibility while preserving the natural characteristics of the speaker's voice. The result is RadioClear AI , a new noise-reduction system combining adaptive digital signal processing with a recurrent neural network and complex temporal filtering. Comparison With RNNoise RadioClear AI and RNNoise both use neural networks to improve speech intelligibility by reducing unwanted background noise, but they employ different approaches. RNNoise is a well-established, computationally efficient solution that combines traditional signal processing with recurrent neural networks to estimate frequency-dependent suppression gains. It performs well across a variety of speech applications and has the advantage of being lightweight and widely tested. RadioClear AI has been developed specifically with radio communications in mind, particularly weak SSB signals affected by receiver noise. It combines adaptive noise estimation and speech-aware spectral processing with a recurrent neural network that generates complex temporal filter coefficients. Unlike conventional gain-based suppression, this approach uses information from consecutive audio frames to adjust both the amplitude and phase of the enhanced signal. Both approaches have strengths, and their relative performance depends on the type of interference, signal conditions and training material. RNNoise benefits from its maturity, efficiency and general-purpose design, while RadioClear offers a more specialised processing architecture tailored to weak radio reception. In initial listening tests, RadioClear AI has produced encouraging results, with cleaner background noise and natural-sounding speech compared with RNNoise on the signals tested. However, these observations are subjective, and controlled comparisons across a wider range of recordings would be needed to establish a consistent performance advantage. Further improvements to RadioClear's training data are planned, particularly using cleaner speech recordings and a greater variety of speakers and receiver noise conditions. Combining Traditional DSP with Artificial Intelligence Rather than relying entirely on artificial intelligence, RadioClear AI uses two complementary processing stages. The first stage is based on conventional digital signal processing. It continuously estimates the background noise and analyses the incoming audio to identify frequencies likely to contain speech. It also examines harmonic relationships, which are particularly important for voiced speech. This information is used by an adaptive spectral suppressor to reduce background noise while protecting important speech components. The result is an initial noise-reduced signal that provides a stable foundation for the neural network. This arrangement has an important advantage. The neural network does not need to learn everything about noise estimation and suppression from scratch. Instead, it receives a partially cleaned signal together with detailed information about the speech and noise characteristics. The neural network can then concentrate on improving the result. Looking Beyond Individual Audio Frames One of the limitations of conventional spectral noise reduction is that it generally operates by adjusting the amplitude of individual frequency components. However, speech is not a collection of unrelated frequencies. It is a continuously evolving signal with strong relationships between consecutive moments in time. RadioClear AI takes advantage of this. The incoming audio is divided into overlapping frames, and each frame is converted into a frequency-domain representation using a Fast Fourier Transform (FFT). The neural network receives 400 features describing the signal across 40 frequency bands. These include information about signal power, estimated noise, signal-to-noise ratio, speech probability, harmonic content and the relationships between consecutive complex spectra. At the heart of the system are two Gated Recurrent Unit (GRU) layers. Unlike a simple feed-forward neural network, a GRU maintains information about previous frames, allowing the system to recognise how speech changes over time. This temporal information is particularly valuable when the speech is partially obscured by noise. Complex Temporal Filtering The most significant difference between RadioClear AI and a conventional neural noise reducer is the way the network processes the audio. Many neural noise-reduction systems generate a set of gains that are applied to individual frequency bins. Although effective, this approach primarily controls amplitude. RadioClear AI goes further by generating complex-valued filter coefficients . For each frequency bin, the system combines information from the current audio frame and the previous two frames. The neural network determines how these spectra should be combined to produce the enhanced signal. Because the coefficients are complex, the system can modify both amplitude and phase. It can also exploit the relationships between consecutive frames rather than treating each frame independently. This gives the network considerably more flexibility than a conventional spectral gain mask. The neural network produces coefficients for 40 frequency bands, which are interpolated across the 257 FFT frequency bins. A three-tap complex temporal filter then generates the enhanced spectrum, which is converted back into audio. The complete process operates continuously in real time. Training the Neural Network The neural network is trained offline using examples of speech mixed with receiver noise. During training, the system is provided with both the noisy signal and the corresponding clean speech. It learns to generate complex filter coefficients that make the processed spectrum resemble the clean reference as closely as possible. An important development decision was to train the network against the actual reconstructed complex spectrum , rather than simply asking it to reproduce a set of ideal filter coefficients. This means the training process directly rewards improvements in the enhanced signal. The current network contains approximately 568,000 parameters and was trained using speech mixed with real receiver noise at signal-to-noise ratios ranging from +15 dB to −10 dB. The training and evaluation process showed substantial reductions in complex spectral error compared with the initial deterministic noise-reduction stage. The improvements were particularly encouraging at the lowest signal-to-noise ratios, where additional noise reduction is most valuable. Of course, mathematical measurements are only part of the story. A lower spectral error does not automatically guarantee better-sounding speech, so listening tests remain essential. Real-Time Processing and Listening Results The neural network was originally developed and trained using Python and PyTorch. The complete inference engine was then implemented in C++ for integration into SDR Console. To ensure that the C++ implementation behaved correctly, its results were compared directly with the Python reference. This included the recurrent network, complex coefficient generation, frequency interpolation and final spectral filtering. The results agreed to floating-point precision, giving confidence that the real-time implementation reproduces the trained model accurately. Initial listening tests have been very encouraging. On weak SSB signals, RadioClear AI produces natural-sounding speech with substantial background-noise reduction. In my own listening comparisons, the results have been noticeably better than RNNoise, particularly in preserving speech quality while reducing unwanted noise. An additional aggressiveness control has also proved useful, allowing stronger suppression of residual noise where desired. As always, the best setting depends on the received signal. Maximum noise reduction is not necessarily the same as maximum intelligibility, so the listener retains control over the amount of processing applied. What Comes Next? Although the current results are very promising, development is far from finished. One area where I expect further improvements is the training material. The first model was trained using a relatively small amount of speech, and the supposedly clean reference recording contained a little background noise. This is not ideal. If noise is present in the clean training reference, the network can learn to preserve some of that noise because it is treated as part of the wanted signal. The next step will therefore be to create a much better training dataset using genuinely clean speech recordings, ideally from several different speakers, together with a wider variety of real receiver noise. I intend to retain the existing neural architecture initially so that improvements from better training data can be evaluated independently. There is also potential to extend the system to other receiving modes, including AM and music, while retaining the existing 8 kHz neural processing engine. Final Thoughts RadioClear AI represents a significant step forward in my work on speech noise reduction for SDR Console. The most interesting aspect is not simply that it uses artificial intelligence, but how conventional DSP, recurrent neural processing and complex temporal filtering work together . By combining an adaptive noise estimator, speech-aware spectral processing and a neural network capable of exploiting relationships between consecutive audio frames, the system can perform noise reduction that would be difficult to achieve using conventional spectral attenuation alone. The aim has always been straightforward: make weak radio signals easier and more pleasant to listen to, without destroying the speech we are trying to recover. The initial results suggest that this approach has considerable potential, and I look forward to seeing how much further it can be improved with better training recordings. RadioClear AI is still evolving, but it is already producing some of the best weak-signal speech noise reduction I have achieved in SDR Console.
